Serena_C
  • 814
  • 39
  • 82
Message 41 of 60
Re: Hub 3 Reboots
Hi @BGL
Sorry to hear that you Hub has dropped out again, I have checked your account and can see that you are currently experiencing a prolonged signal levels issue. Please can you try performing a pin hole reset on your Hub by following these exact instructions:
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Please let me know if things improve after this.
Our engineers don't record anything other than if they have attended, unfortunately we can't see any of the notes they put in.
Apologies,
Serena
BGL
  • 42
Message 42 of 60
Re: Hub 3 Reboots
Hello,
A pinhole reset has been performed previously, the last two engineers confirmed a network fault,  the phone number to check faults does not show any issues when there is one - a 'cardiograph' on the last engineer visit showed the SNR Upstream drops and networks should be aware of the fault.
(Engineer when asked for a fault code, said it would be logged against my account)
As this has been ongoing for some time now can you escalate this issue please?
HUB 3 - Direct Ethernet Connection
My Broadband Ping - BGL1
Hayley_S
  • 1.12K
  • 32
  • 84
Message 43 of 60
Re: Hub 3 Reboots
Hello @BGL,
I am sorry for everything.
Please can you try plugging your Hub into a different power outlet? Also please make sure the Hub is well ventilated.
Also a pinhole reset if you haven't done this already 🙂
Let me know how this goes.
Many thanks,
Hayley
BGL
  • 42
Message 44 of 60
Re: Hub 3 Reboots
I've been experiencing issues for a very long time now and only started to push for a resolution due to working from home. (Previously due to work requirements for out of hours support, I paid for a separate ADSL broadband connection to ensure I could work when the SuperHub2 dropped offline).
The SuperHub 3 exhibits the same issues as the SuperHub2, however resets much faster (about 6 mins) this is frustrating as myself / partner work from home and rely on this connection.
Information on what has been done:
Cabling inside checked and HUB reset fully.
Recent Engineer visits (I can recall)
  1. Engineer visits, fault identified with the box that the cable enters my property and replaced parts.
  2. Engineer visits,  identified an issue with the cable under my garden and had it replaced
  3. Engineer visits,  identified an issue on the VM network and noted my neighbour's HUB resetting at the same time as mine
  4. Engineer visits, no knowledge of previous history – all my equipment checks out fine, noise issue noted on upstream SNR and raised to Networks
  5. Engineer visits, no knowledge of previous history – all my equipment checks out fine, networks report an issue in the area that was resolved at 8.30am a few hours before the engineer arrived
  6. Engineer visits,  noise issue noted on the SNR upstream and a 'cardiograph' for the last three days confirms it - raised to Networks who report awareness of the fault, asked for a reference code and was informed it would be on my account
  7. VM Tests have given me the following, reporting a Network fault
Contacting the suggested number 0800 561 0061 reports no issues - when I'm not connected.
Things not done:
Original Telewest Box inside house looked at, HUB replaced (Superhub2 had issue also so unlikely this imo).
As all the on site investigations and the VM test shows though, the issue is with the Network (as shown with the neighbour issue at the same time)
Can you please investigate the issue with the network team/escalate?
Travis_M
  • 918
  • 37
  • 69
Message 45 of 60
Re: Hub 3 Reboots
Hi @BGL
I'm awaiting a response from my colleague to see if the tech has came back surrounding this, i'd like to get this sorted for you.
Travis_M
BGL
  • 42
Message 46 of 60
Re: Hub 3 Reboots
Did you hear anything back?
I haven't had any drop outs now for two weeks - I can see that using Fast.com my client is now identified as 'Leigh, GB' where previously it reported as Orrell.
Geographically I'd say Leigh is around four times closer to me so suspect this shift may have helped...
Gareth_L
  • 6.93K
  • 424
  • 781
Message 47 of 60
Re: Hub 3 Reboots
Hi BGL
Can you pleas keep us updated if this resorts back to dropping out again
Sounds like its doing okay right now
But we are here to help
Gareth_L
BGL
  • 42
Message 48 of 60
Re: Hub 3 Reboots
Had another drop out just now and looking at my BQM logs can see a drop out on the 11 of this month around 3am.
Have you had any feedback on this yet from the network team?
Gareth_L
  • 6.93K
  • 424
  • 781
Message 49 of 60
Re: Hub 3 Reboots
Hello BGL
I cannot see anything on the account that relates to the drop at 3am
Gareth_L
BGL
  • 42
Message 50 of 60
Re: Hub 3 Reboots
I've just had another drop out - can someone please advise further?
