For many months / years, my HUB 3 will randomly reboot then reconnect after 15mins or so.
A few visits, swapped Hub and attenuators installed etc.
Following an engineer visit to check things the other week a cable fault was identified under my garden and subsequently swapped out..
This week the reboots have continued and the engineer has now noted that a neighbours' HUB had also reset at the same time as mine suggesting a 'network fault that would need raising to the network team'
Does anyone have any experience of similar faults and is there hope that they will finally resolve this? (This does not show on the service checker as a fault which is also annoying)
If they monitor for a week without the issue popping up and close the fault I won't be happy when it returns 😕
HUB 3 - Direct Ethernet Connection
