  • 33
Message 1 of 5
Hub 3 Not Accessible Now In Modem Mode
Hello,
Not having much luck with my newly installed Hub 3. I tried using it in modem mode with my existing TP-Link VR900 which supports this feature and didn't get anywhere. I could see my TP-Link via WI-Fi and connect to it, but no Internet was coming through.
Anyway, giving up on that idea, I set about configuring the Hub 3 back to regular router/modem mode. To do this, I ran an Ethernet cable direct from the laptop to the Hub 3 and in my browser address bar, typed:
192.168.0.1
Nothing!
I've tried each of the Ethernet ports on the back of the Hub 3 and have configured my static Ethernet port on my laptop address as 192.168.0.115. The router address cannot be pinged and I am at a total loss as to how to return this router to standard mode.
Please help!
  • 24.94K
  • 1.44K
  • 3.17K
Message 2 of 5
Re: Hub 3 Not Accessible Now In Modem Mode
The TP-Link VR900 is a ADSL/VDSL router and not suitable for cable connections like Virgin.
To get back to router mode you’ll need to either factory reset the hub or go to 192.168.100.1 in a browser.
  • 12.06K
  • 939
  • 1.54K
Message 3 of 5
In Modem Mode the IP Address for the Hub is 192.168.10.1
Mike Robinson
  • 33
Message 4 of 5
Thanks!! You're a genius! 🙂
Actually, I got my TP-Link router wrong. Looking at the listing in the Network infrastructure category, I have a Archer VR200 from TP-Link. I did look through the docs on this and it was stated it can accept DSL, cable and fibre connections when in "Wireless router" mode. Perhaps the type of signal coming from Virgin isn't compatible with any of those?
I was pondering seeing if there were any non ISP provided routers that might support the Hub 3 in modem mode. Would you by chance know of any?
  • 24.94K
  • 1.44K
  • 3.17K
Message 5 of 5
I think it will work but you need to make a few setting changes to get it working.
Have a look at any mid-high range TP-Link (not VDSL) or ASUS router.
