There are 2 passwords one for wifi and one for settings - did you put the correct one in - if not try the other one. If neither work you must have changed it to something else some time ago.
To revert them back to those on the sticker do a Hub “pinhole reset”. Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 10’ to stabilise - dont manually switch it off at any time.
