I have a Hub 3 and recently added a Deco M4 mesh system to my home network. I now need to put my Hub 3 in Modem Mode for this to work properly. [This was advice from Deco support, in order to get my NAS and my Sonos system to work properly with the Deco mesh.]
My questions:
- Other posts in this forum say that, when the Hub 3 is in Modem Mode, only one Ethernet port on the Hub 3 will work (the one used to connect it to the Deco).
- Is this correct?
- If so, how do I know which port to use? (other than trial-and-error)
- Am I correct that I then need a network switch, connected to my Deco, for all other ethernet-connected devices?
- Once I have the Hub 3 in Modem Mode, can I access the 192.168.100.1 IP address for its control panel via the WiFi SSID from my Deco? (i.e. Is that IP address "visible" from the Deco subnet?
Thank you,
Daryl
