Hub 3 Lan connection issues
Arron225
Since I've brought a 500mbs hub 3 package I've been having issues with the LAN connection when connecting it to my Ps5, based on a speed test I've just done, the Internet speed via lan cable is 37.5 mbs when compared to getting around 330mbs on WiFi (both values are for download speeds). Further to this my Hub 3 has been stuck on yellow ever since its been installed. I have changed the LAN cables round but nothing has changed with the speed. I have called to virgin media support about this issue multiple times and one time someone hung up on me after agreeing that LAN connection shoukd be faster than WiFi. Does anyone know how to resolve this?
5 REPLIES 5
Arron225
I have also seen someone have a similar issue that was resolved but I am unsure on how to solve it
Have you first tried a known good, new Cat6a ethernet cable?  Old cables can, and do fail, usually defaulting to sub 100 Mbps speeds
Legend
To check, connect your PS5 directly to the Hub 3 using a network cable.
Now login in to the Hub 3's menu at http://192.168.0.1/   ( use the 8 digit password )
Visit the Connected devices page and check if the PS5 is connected at 10/100/1000 Mb/s.
We are expecting to see a 1000 Mbps Ethernet connection.
Thanks for responding, the connection shows that it is a 100mbs, not 1000
And I'm using a new LAN cable, though I did compare it to the one I did use days prior (before I moved into my new house) and it was performing well at similar Internet speeds
