on 02-09-2023 21:23
Hi, my hub3 has been dropping wifi signal and giving poor wifi range for a while now and i have tried most suggestions to rectify it, but no improvement. I think it is around 5 years old and seems to get pretty warm, so not sure if it is age related.
is there a way I can get an upgrade to the latest hub?
thanks
on 05-09-2023 09:38
Hi there @AdamWiggy
Thank you so much for your post and welcome to the community forums, it's great to have you here and with the team.
I am so sorry that you have been facing these issues with your service and thank you again for your post.
I have been unable to locate your account via your forum details so we can check things on our side but I will pop you a Private Message so we can grab some information and take a look.
on 05-09-2023 11:03
Thank you for chatting with me via the PM @AdamWiggy and I have now been able to locate the account.
I can see the Hub has been up for over two weeks, are you able to try a pinhole reset for us?
To do this push a pen etc into the reset hole at the back of the Hub and hold in for 60 seconds, this will force a full factory reset so if you have changed the Hub setting at all they will revert to the original settings.
on 05-09-2023 13:30
I have done this multiple times and it never seems to improve, but I will try it again today…
on 05-09-2023 16:21
I have reset the hub but there is no difference, wifi still very unreliable and drops on/off.
on 07-09-2023 14:10
Hi, i did the reset but it hasnt improved.
on 09-09-2023 15:57
Hi AdamWiggy 👋
Thanks for providing us with an update on this. I'm sorry to hear the issue hasn't been resolved after a reset on the Hub. I've taken a look and can see your Hub Levels have fallen out of specification throughout the last few weeks, which can indicate a problem with the incoming signal, which in turn can lead to intermittent service.
I can see you've recently been in a private message with my colleague, so I'll pick this up on their behalf. Please look out for my message in the top-right, white envelope or the "Messages" tab after tapping your profile picture.
