Paul_DN
  • 10.29K
  • 526
  • 1.04K
Message 21 of 60
Re: Hub 3 Disconnections
Hi Sweet16,
Thank you for reaching out to us in our community and welcome back, I was able to locate your account with the details we have for you, I have run checks our end, so I can run further checks please can you try the below?
The test results show you are having a connection issue to your Hub,
This can be caused by loose connections in the cabling in your home, so before I complete my checks, are you able to check that:
• All cables between the wall and your Hub are secure. This includes any screw or ‘push on’ connections. If you also have our Virgin TV service, can you check the connections on that kit too.
• Any wall points or cables that don’t have anything connected to them have a cap cover for the connection point?
Paul.
Sweet16
  • 32
  • 7
Message 22 of 60
Hi Paul,
Thank you for your response and initial checks on my connection. I can confirm that all cable connections ( incoming cable, hub and TiVo box are all tight and secure.
Sweet16
  • 32
  • 7
Message 23 of 60
Hi Paul,
Just a quick message to ask if you had a chance to investigate my plight further and if any issues had been identified?
Kind Regards
Kain_W
  • 3.29K
  • 93
  • 228
Message 24 of 60
Hi there Sweet16,
Thanks for your updates and welcome back to the page.
From reviewing your account I can't necessarily see anything that outline the issues you are facing.
Your BQM posted previously seems to reflect what we can see, do you have any recent readings from days you've experienced issues.
Your uptime on your box is touching its 5th day, if you are still facing issue since posting I'd advise to reboot your system and allow 1 minute before switching it back on.
Kain
Sweet16
  • 32
  • 7
Message 25 of 60
Hi Kain,
Unfortunately, the hub has just again disconnected itself impacting both wifi and Ethernet connections and I have had to reboot again. This is far from convenient, especially if I was not at home and unable to reboot. The issue must be either the hub itself or an exterior fault on my service cable or beyond. Is there no way of having the hub replaced which if nothing else will at least eliminate that possibility?.
I am sure you appreciate how frustrating this is and hardly a great advert for cutting edge technology from VM.
Msinclair9981
  • 36
Message 26 of 60
I had exactly same daily  issues as you for 8 weeks and 8 different engineers attend and swap various cables/attenuators etc and replaced the  superhub  3 twice, and the problem still persisted. They were out of ideas and suggested last resort to drop a new line to my house!
well I found another post on here and sounds like the hub 3s are no longer able to cope with many devices attached and timeout at random intervals
ive flipped my hub to modem only mode and bought a router (tp-link archer ax50) and had no dropout since I installed it on Sunday. Sadly the wifi speed around my house is a bit less than the superhub managed, but crucially no dropouts.
I fear virgin refuse to acknowledge their hubs are not up to the job given the number of similar posts. There are plenty of posts on here with similar symptoms. Best of luck.
Sweet16
  • 32
  • 7
Message 27 of 60
Thank you for replying to my post and for providing me with an update on your similar experiences.
I have suffered these disconnections over several months but my patience is now being tested somewhat. It came to a head several weeks ago whilst on holiday where I had no access to my Hive equipment for over a week. It was only resolved when a relative drove a 40 mile round trip to my house to reboot the hub. Hardly space age technology. . . . Good job the International Space station doesn’t depend on VM equipment. Lol.
Frustration boils when calling the VM contact centre and suffering the usual scripted dialogue then being told everything is fine and my connection will be monitored. Was also told that I needed to upgrade which would resolve the problem. Why would I upgrade something which doesn’t work?.
Contemplating installing a router and switching hub3 to modem mode , like you have yourself done. I am, however, reluctant  to proceed incase I end up with the same situation and then being told by VM that the problem must be my own equipment.
Thanks again.
Sweet16
  • 32
  • 7
Message 28 of 60
Here we go AGAIN.
Hub 3 dropped out again at 0100hrs this morning. Log shows it again coincides with the message NOTICE ATOM. Wife tried to reset but nothing. Still off at 0915 this morning but reconnected after another reboot. I previously complained that this connection was unreliable if trying to use smart technology when away from home. Now I can’t even go to bed with any confidence that it will still be working when I get up.
BQM recording normally so nothing showing there.
Can anyone suggest where I go from here?
At my wits end and honestly feel like launching hub onto street and asking VM to collect it when they drive past. The options I see open to me are
1/ VM actions a solution and provides me with some surety and reliability.
2/ I take a chance and install a third party router with Hub 3 on modem mode. This puts all risk on me and might not resolve issue
3/ I operate hub mains through a mechanical time switch which automatically switches supply off for a few minutes every night to allow a reset of hub. This should be an embarrassment to VM if this is required
4/ Instruct BM to disconnect and change to BT. This undoubtedly means a slower connection but at least I have reliability.
HELP PLEASE
Sweet16
  • 32
  • 7
Message 29 of 60
Further to previous posting. I should reaffirm that Hub 3 outage impacts all Wifi and Ethernet connected equipment
Paul_DN
  • 10.29K
  • 526
  • 1.04K
Message 30 of 60
Hi Sweet16,
Sorry to see you are still facing the same issues, I have had a look our end and cannot see any issues at all, I have run some further test, and it has advised to rule out a software issue, first check all the internal connections are hand tight then push a pin/ paper clip in the back of the Router where it says reset, push in until you feel it press then hold in for a timed 1 Minute, do not reboot during or after and allow 15 Minutes to settle afterwards?
Paul.
