  • 20
Message 1 of 12
Hub (3) Constantly rebooting
Hallo.
Over the past month or two, my Hub 3 has been constantly rebooting. It's just done it six times in three hours.
It is in modem mode. Also worth noting is the fact that the box on the outside of my house where the VM wires come in has been damaged over the years by refuse collectors, window cleaners, etc., with the cables protruding.
I've tried recycling the Hub, to no avail. Possibly trying a new hub would help (I've had it for years), or perhaps it's the box on the house wall?
Thanks in advance.
Ian.
  • 12.06K
  • 939
  • 1.54K
Message 2 of 12
Re: Hub (3) Constantly rebooting
Before you retire for the night, switch the Hub off using the small switch on the rear of the Hub and unplug the PSU from the wall socket.
Leave it like that overnight then switch it back on in the morning and see how it is.
Mike Robinson
  • 20
Message 3 of 12
Thanks. I'll try that....
Ian.
  • 7.72K
  • 614
  • 1.32K
Message 4 of 12
VM hubs very very rarely reboot. What happens is they lose their connection to the VM CMTS ( the other end of your cable ) and try to reconnect, they then keep on trying until the connection is established. It’s often due to circuit problems, bad connections or noise ingress. Please go into your hub on 192.168.100.1 and post your up/downstream stats and network log.
  • 20
Message 5 of 12
Well, the prolonged power dwn improved it somewhat, but it still reboots 4-5 times a day.
Thanks for the replies so far.
06/11/2020 13:06:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 13:06:14Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:48:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:48:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:46:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:46:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:44:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:44:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:43:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:43:36Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:38:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:38:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:37:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:37:36Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:36:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:36:38Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:36:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:36:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:35:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:35:44Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20
Message 6 of 12
Latest Logs:
09/11/2020 21:35:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 21:35:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 14:50:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 14:49:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:44:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:44:16ErrorDCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:34:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:34:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 11:07:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 11:06:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:34:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:34:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:27:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:27:57Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:16:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 07:16:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 06:48:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 06:48:1Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 06:38:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 06:38:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20
Message 7 of 12
1298750000-1.240256 qam21
2138750000140256 qam1
3146750000140256 qam2
41547500000.740256 qam3
51627500000.238256 qam4
6170750000-0.238256 qam5
7178750000-0.540256 qam6
8186750000-0.740256 qam7
9194750000-0.940256 qam8
10202750000-140256 qam9
11210750000-0.938256 qam10
12218750000-0.936256 qam11
13226750000-0.931256 qam12
14234750000-0.740256 qam13
15242750000-140256 qam14
16250750000-140256 qam15
17258750000-140256 qam16
18266750000-0.940256 qam17
19274750000-1.240256 qam18
20282750000-0.940256 qam19
21290750000-1.240256 qam20
22306750000-1.240256 qam22
23314750000-1.540256 qam23
24322750000-1.740256 qam24
  • 3.66K
  • 286
  • 514
Superfast
Message 8 of 12
You've got a problem with your line.
  • 20
Message 9 of 12
15369997647512064 qam5
22580000047512064 qam4
33260000048.5512064 qam3
43939995447512064 qam2
3ATDMA0000
4ATDMA0020
  • 1.42K
  • 87
  • 272
Message 10 of 12
Hi IanR,
Thank you for reaching out with your broadband issues, I'm sorry that you've been having trouble with your hub.
I can't see any evidence of your equipment struggling to maintain a connection on the network. However, the downstream SNR being reported by your hub is a little low on some channels. I'd be happy to arrange an engineer visit to look into this for you. If they identify that the damaged omnibox is the underlying cause, they will go ahead and replace this for you.
Of course, we'd never request sensitive information via an open platform so I'll send you a private message to complete account security and get everything booked in. Please head to the purple envelope in the top right corner to respond.
Rachael
