  • 8
Message 1 of 8
Hub 3 Connected with No Internet
My wifi keeps dropping out saying it is connected with no Internet. It has been doing this a few times everyday for the last couple of weeks, I am on the 200mbps service. I have tried rebooting and resetting my hub but the issue keeps happening and it happens on every device.
I only recently upgraded my service and I am only receiving speeds around 20mbps.
The hub only has the white power light on nothing else.
  • 3.67K
  • 288
  • 516
Superfast
Message 2 of 8
Re: Hub 3 Connected with No Internet
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
  • 8
Message 3 of 8
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
451000000
0.7
40
256 qam
40
2
267000000
1.7
40
256 qam
17
3
275000000
1.7
40
256 qam
18
4
283000000
1.9
40
256 qam
19
5
291000000
1.9
40
256 qam
20
6
299000000
2
40
256 qam
21
7
307000000
2
40
256 qam
22
8
315000000
2.2
40
256 qam
23
9
323000000
2.2
40
256 qam
24
10
331000000
2.2
40
256 qam
25
11
339000000
2
40
256 qam
26
12
347000000
1.9
40
256 qam
27
13
355000000
1.7
40
256 qam
28
14
363000000
1.5
40
256 qam
29
15
371000000
1.2
40
256 qam
30
16
379000000
1.2
40
256 qam
31
17
387000000
1
40
256 qam
32
18
395000000
1
40
256 qam
33
19
403000000
1
40
256 qam
34
20
411000000
1.2
40
256 qam
35
21
419000000
1
40
256 qam
36
22
427000000
0.9
40
256 qam
37
23
435000000
0.7
40
256 qam
38
24
443000000
0.7
40
256 qam
39
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
0
0
2
Locked
40.9
4
0
3
Locked
40.3
3
0
4
Locked
40.3
5
0
5
Locked
40.9
5
0
6
Locked
40.3
5
0
7
Locked
40.9
4
0
8
Locked
40.9
5
0
9
Locked
40.9
4
0
10
Locked
40.3
5
0
11
Locked
40.9
4
0
12
Locked
40.9
4
0
13
Locked
40.9
4
0
14
Locked
40.3
4
0
15
Locked
40.3
12
0
16
Locked
40.9
4
0
17
Locked
40.9
19
0
18
Locked
40.9
4
0
19
Locked
40.3
5
0
20
Locked
40.9
4
0
21
Locked
40.9
5
0
22
Locked
40.9
18
0
23
Locked
40.3
4
0
24
Locked
40.3
5
0
  • 8
Message 4 of 8
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32599974
42.5
5120
64 qam
13
2
39399996
42.5
5120
64 qam
12
3
46199983
42.5
5120
64 qam
11
4
53700014
42.5
5120
64 qam
10
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 8
Message 5 of 8
Time
Priority
Description
22/11/2020 15:37:22
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 16:41:40
critical
19/11/2020 21:17:18
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 21:17:18
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 13:51:48
critical
16/11/2020 12:12:24
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 07:41:47
critical
13/11/2020 10:25:7
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 10:25:7
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 10:25:7
critical
13/11/2020 10:25:5
Warning!
12/11/2020 17:31:34
notice
12/11/2020 17:31:34
Error
11/11/2020 12:28:50
notice
11/11/2020 12:28:50
Error
05/11/2020 16:45:13
critical
05/11/2020 11:29:43
Warning!
05/11/2020 11:29:43
critical
05/11/2020 11:29:43
Warning!
05/11/2020 11:29:36
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 25.14K
  • 1.44K
  • 3.2K
Message 6 of 8
What are wired speeds and connectivity like?
  • 8
Message 7 of 8
Wired speed is great around 200mbps tonight and haven't noticed any connectivity issues using ethernet cables just wifi.
  • 25.14K
  • 1.44K
  • 3.2K
Message 8 of 8
OK.
So first step is to do a 60 second pinhole reset on the hub.
And if that doesn’t solve it then look into getting your own router or mesh system
