henryscow
Hub 3: 5GHz network missing
Hi there
I recently spotted that the 5GHz signal on my Hub 3 router has gone missing. I contacted your team on Twitter, who advised me to hold down the reset button for >60s (you can see the conversation here)
However, I have done this twice and it has not resolved the issue. Please can someone help?
H
Tags (3)
  • 20.43K
  • 2.18K
  • 3.61K
Re: Hub 3: 5GHz network missing
Check in the Hub settings that the "Disable wifi" box is not ticked for 5GHz channel. Try clicking it on and off and saving settings inbetween
henryscow
This is now resolved - a third attempt at a hard reset (>60s) caused the original SSIDs to reappear (2.4GHz and 5Ghz). I had a further problem with my booster boxes continuing to broadcast the old SSID - also solved (by logging in to them and change them manually).
All up and running again - thanks for your help.
