I have just run network diagnostics on my Hub 3.0 after pinhole rest and buying extenders has failed to solve ongoing WiFi issues.
The diagnostics say there are no issues with:
gateway IPv4
Broadband connection
temp of hub
but then says that every single device currently connected to the hub has low signal strength and I need to move it closer to the hub (including the iPad I am doing the diagnostics on, sat right ne t to the hub!)
Has the WiFi transmitter in the hub given up the ghost, or is there some way I can fix this?
thanks
