Hi There,
For the past week or so I have been experiencing dropouts in my WiFi wireless connection. This has impacted video calls and working from home issues.
I am really baffled as to what has caused this problem and finding out how to resolve this.
Basically, since I have had internet and have been using all my devices using WiFi (wireless) connection and they have been working great and I run an access point for where I don’t have good wifi strength. Last week I noticed that my internet on my phone (and all other devices) would cut out randomly and I would have to search for the WiFi again to connect to the network.
I used ookla to run some speed testing on these wireless devices, testing and re-testing in the same location one test after another resulting in varying download speeds (fairly consistent uploads), and then randomly the internet connection would drop until I manually search for the WiFi router and connect back sometimes it would be within seconds sometimes minutes. This has been getting worse and worse.
I also run a Unifi Access Point – Ubiquiti UAP-AC-LITE, for the back of the house in my office and I have never had any issues with this it provides connection where signal is weak, it has been the best thing. Now it has faced the same problems as the router when the connection is disrupted on the Router it will also occur on the Access Point (im not sure if this is simultaneously or at the same time). Sometimes it takes seconds to reconnect sometimes it takes longer. On some devices when I try to reconnect straight after the connection has dropped it will say “Incorrect Password” upon connecting to either the router or access point.
No changes have been made to my hardware which is what is baffling me. I have checked all termination points, Coaxial termination externally and internally, all finger tight connections. There are no obvious kinks running in any of the wiring.
I have reconnected all ports and reset the hub.
The only thing which may have remotely had an effect is the electricity power was turned off to add sockets to a different room in the house. So maybe the access point has turned off and the WiFi router has turned off at different points affecting signalling between the two? But surely Resetting this would have brought things back in line?
Since then, I have disconnected my Access Point so I am only using the Router. I am still experiencing the same issues with the Hub 3.0 whilst within close proximity. Checked the ookla speeds and same results - they are varying.
Now I have managed to use the same Ethernet that was connected to the Access point to my laptop and now I am not experiencing such dropouts (but I am not holding my breath). But I don’t understand why there is problems with my access point when diagnostic show it is working ok as well as my router having issues, as well as the fact that I haven’t changed my setup.
Can anyone share light on this matter. I really wish I could understand these networking issues abit better and troubleshoot. Apologies for the long story or any information which I haven’t included I hope someone can help me.
