Hub 3.0 stuck in “update in progress”
Avere
my hub 3.0 has been stuck in update on progress for acquired downstream channel and ranges upstream channel for 5 hours now. I have rebooted, restarted and restored to factory settings. Nothing is working. Please help so I can have wifi again.
1 ACCEPTED SOLUTION
Accepted Solutions
Avere
It didn’t work but thank you, I have a technician coming tomorrow to fix it.
3 REPLIES 3
Legend
Customer Support are on 150 or 0345 454 1111 from a non-VM phone. Log this as a Hub fault / failure.
Try a factory reset again like this
______________________________
With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords and SSID’s will reset to those on the sticker so log in and change them back to what they were/should be.
Avere
