meejahoar
Message 1 of 84
Hub 3.0 settings password not working
Hub 3.0 settings password (which is printed on the bottom of the router) isn't working. Does Virgin reset this with a different default password and if so how do I get it?
nodrogd
  • 16.8K
  • 1.97K
  • 4.08K
Message 2 of 84
Re: Hub 3.0 settings password not working
You are using the correct one?
There are two passwords on the bottom of the Hub3, the WiFi password & the Admin password.
If you are using the correct one have you tried the pinhole reset?
Hub 3 labelHub 3 label
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
Rebecca_G
  • 961
  • 54
  • 68
Message 3 of 84
Hey meejahoar,
Thanks for getting in touch and Welcome to the Community! 🙂
The settings password is used to log in to your Hub online and is usually a number. If you're trying to connect a device, you'll need to use the WiFi password.
As nodrogd said, if you're using the correct password then a pin hole reset will set the Hub back to default settings and should then let you connect.
If you need any further help, let us know.
Take care
Rebecca
New around here? Find out more about the Community by checking our "Getting started guide"
tonewheelkev
  • 35
Message 4 of 84
Tried the pin reset...(how would I know if that had been effective?)....still the default password not working.
Jen_A
  • 15.16K
  • 511
  • 1.85K
Message 5 of 84
Hi tonewheelkev,
To perform an external reset of your Hub:
  1. Find the Ethernet ports on the back of the Hub 3.0
  2. Below the Ethernet points, you will see a pinhole marked 'RESET'. Use a paper clip or pen to press the pinhole reset button for 20 seconds
  3. The Hub 3.0 should now revert to its factory default settings – the same as those listed on the label on the bottom of the device
  4. We recommend that you now turn off the power to the Hub 3.0 for 60 seconds and then turn it back on
Once you've done that the Hub should revert back to the default Settings Password.
This should work for you so please keep us updated 🙂
Jen
xiano93
Message 6 of 84
I did an external reset but still can't get the configuration to work.
Heather_J
  • 12.75K
  • 403
  • 735
Message 7 of 84
Hello xiano93,
Thanks for letting us know and sorry you're still struggling with this.
I'll get in touch with you via PM (purple envelope, top right) so we can arrange for a replacement to be delivered.
Speak soon,
Take care.
Heather_J
slider91
Message 8 of 84
Hi All, I am having the same issue I have tried the settings password number on the bottom of the hub and have tried it after doing the pin hole reset and it is still stating that the password is incorrect.  Is there anything else I can try please?  Thanks   Simon
thedarkslender
Message 9 of 84
Im having the same problem as well.
RickyB85
Message 10 of 84
Im having the same problem also.
