@howden9 wrote:
Morning,
Can someone please advise if my settings are configured for broadcast at both frequencies - I notice that the 5GHz is ticked - but greyed out
Also, should I rename one of the SSIDs?
If the names are the same and it's ticked by greyed out, then it means it's broadcasting both bands with the same SSID and password.
If you want to define it more, you can rename each band and connect each device to whichever band accordingly.
