geoffcook1
Message 1 of 9
Hub 3.0 red light
My hub has a red light on solid all the time.  It is not overheating but performance is not as good.  It is in modem/router mode.
I have tried resetting and pin method but it is still the same
Please advise
nodrogd
  • 18.74K
  • 2.23K
  • 4.84K
Message 2 of 9
Re: Hub 3.0 red light
This is where it gets confusing if you are using modem mode.
Modem mode is signified by a Magenta light. Over heat warnings produce a Red light.
So the question is has this indication changed from Magenta to Red. If it has either the hub is overheating or it is a faulty indication.
If it is Red after a reboot then replacement is required. If however the hub is showing the correct indication for modem mode there is no fault.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
geoffcook1
Message 3 of 9
It is definitely solid red!,
Tom_W1
  • 3.66K
  • 199
  • 343
Message 4 of 9
Hi @geoffcook1 thanks for your post here in the Community - welcome!
You have said that your Hub is in "modem/router mode", but the two modes are either Modem Mode, or Router Mode. Can you please clarify which mode your Hub is in, as the answer will depend on how we can take things further?
Many thanks
Tom_W
geoffcook1
Message 5 of 9
It is in router mode, there is no additional apparatus attached to it.
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Message 6 of 9
Hi geoffcook1,
Thanks for coming back and confirming that.
As you've already done the pre-checks and the hub is in router mode, I would like to arrange for an engineer to come to take a look at this for you and swap the hub.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a private message regarding this. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
Kath_F
Kath_F
  • 34.71K
  • 1.33K
  • 2.81K
Message 7 of 9
Hi geoffcook1,
Thanks for coming back to via private message to confirm your information.
We're not able to send a replacement as the engineer will need to do some checks to ensure everything is safe.
I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here: My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Lets us know how the appointment goes.
Take care.
Kath_F
geoffcook1
Message 8 of 9
Thanks Kath
Engineer came yesterday and replaced Hub, all working fine.
Good service.
Akua_A
  • 4.72K
  • 122
  • 324
Message 9 of 9
Glad to hear this @geoffcook1 🙂
Please do not hesitate to contact us if you need any further help.
Akua_A
