  • 10
Message 1 of 16
Hub 3.0 rebooting
Hi - Our Hub 3.0 is continually rebooting.
Having read a number of threads it seems we require another visit from a VM engineer. We have had an engineer out and the hub rebooted a few time whilst so they’ve replaced the Hub stating the issue was with the Hub. Surprise surprise this hasn’t fixed the problem.
Spent 50mins on a call trying to get support only for the operative to hang up - great customer service.
Any advice how we can simply get a engineer to revisit and fix the service once and for all? During the original install the engineer stated there was not much for them to connect onto which suggest to me from some of the threads this is an issue with the connection into the house.
  • 11.49K
  • 891
  • 1.46K
Message 2 of 16
Re: Hub 3.0 rebooting
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 10
Message 3 of 16
  • 11.49K
  • 891
  • 1.46K
Message 4 of 16
Go round all the accessible internal and external co-ax connections and ensure that they are good finger tight.
Mike Robinson
  • 10
Message 5 of 16
Hi - rechecked and finger tight - the VM engineer also checked this when he swapped out the hub 3.0 and replaced it with a new one the other week. Additional info.....
  • 10
Message 6 of 16
1 203000000 2 40 256 qam 9
2 211000000 2 40 256 qam 10
3 219000000 1.9 40 256 qam 11
4 227000000 1.4 38 256 qam 12
5 235000000 1.7 38 256 qam 13
6 243000000 1.4 38 256 qam 14
7 251000000 1 40 256 qam 15
8 259000000 1.2 38 256 qam 16
9 267000000 1.4 38 256 qam 17
10 275000000 1.4 40 256 qam 18
11 283000000 1.2 40 256 qam 19
12 291000000 1.4 38 256 qam 20
13 299000000 1.5 38 256 qam 21
14 307000000 1.5 38 256 qam 22
15 315000000 1.5 38 256 qam 23
16 323000000 1.5 38 256 qam 24
17 331000000 1.5 38 256 qam 25
18 371000000 1.2 38 256 qam 26
19 379000000 1 38 256 qam 27
20 387000000 1 38 256 qam 28
21 395000000 1 38 256 qam 29
22 403000000 0.9 38 256 qam 30
23 411000000 0.7 38 256 qam 31
24 419000000 0.7 38 256 qam 32
1 Locked 40.3 4 0
2 Locked 40.3 5 0
3 Locked 40.3 4 0
4 Locked 38.9 0 0
5 Locked 38.6 4 0
6 Locked 38.9 5 0
7 Locked 40.3 0 0
8 Locked 38.9 7 0
9 Locked 38.9 5 0
10 Locked 40.3 5 0
11 Locked 40.3 6 0
12 Locked 38.9 6 0
13 Locked 38.9 5 0
14 Locked 38.9 6 0
15 Locked 38.9 5 0
16 Locked 38.9 0 0
17 Locked 38.6 3 0
18 Locked 38.9 5 0
19 Locked 38.9 6 0
20 Locked 38.9 5 0
21 Locked 38.6 5 0
22 Locked 38.9 6 0
23 Locked 38.9 1 0
24 Locked 38.6 4 0
  • 10
Message 7 of 16
1326000004.775512032 qam5
2394000004.825512064 qam4
3462000004.9512032 qam3
4537000005.075512064 qam2
3ATDMA0000
4ATDMA0000
  • 10
Message 8 of 16
Network log:
02/11/2020 17:18:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 17:17:51criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 16:41:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 16:38:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 16:26:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:57:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:56:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:56:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:54:42criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:38ErrorService Delete rejected - Service flow not found;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:37ErrorService Delete rejected - Service flow not found;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:36ErrorService Delete rejected - Service flow not found;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:50:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 14:53:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 14:52:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 14:49:46criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 14:45:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 10
Message 9 of 16
Any ideas MikeA / anyone?
As we have been dealing with this problem for 2+ months now getting nowhere last week we have raised a complaint. Basically, Virgin Media customer service is pointless and non existent,
Today, unsurprisingly, we received an email closing the complaint down. The response stated we have tried to contact you (they have not) so assume your complaint is resolved.
Without a doubt, dealing with Virgin is the worst customer service experience anyone could ever have to endure. To add insult to injury we spent an hour today trying to get the complaint reopened for yet again (we have stopped counting) the line to go dead.
If anyone from Virgin Media reads this and does value their customers, in fact even cares about customer service please have some decency and contact us to fix the problem. Also, reopen complaint C-271020937. Thanks in desperation...
H
  • 11.49K
  • 891
  • 1.46K
Message 10 of 16
The modulation on two of your four Upstream channels are at 32 QAM, they should be at 64 QAM.
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
