on 25-07-2023 20:40
We had a new hub 3.0 VMDG505/TG2492LG-VM installed a few weeks ago following a lightning strike near a virgin street cabinet nearby.
All has been ok until a few days ago when the bottom LED turned red
The hub is in router mode and i have rebooted it several times but it comes straight up with a red light.
Wifi and ethernet are working ok and the hub is warm but not excessively hot.
The router is in an open ventilated position
I ran a test via the virgin website and it came back with several device wifi issues but when i logged into the router myself using a web browser it showed no issues with the devices connected to wifi.
Any help with this would be greatly appreciated
on 25-07-2023 21:00
Hi cm56, thanks for the message and welcome back to the forums.
I am sorry to hear that you are having issues with the hub and will send you a PM so that we can run some further tests.
Please look out for the message in your inbox.
Kind regards, Chris.
25-07-2023 22:55 - edited 25-07-2023 22:55
OK probably coincidental but the red light has two meanings. Either the hub is overheating (it’s not overheating), or the ‘2p, let’s use the cheapest components in the world’, LED is failing and when LEDs fail, they tend to go red.
So don’t lose to much sleep over it, but it does need to be replaced.
on 26-07-2023 06:24
Sometimes, the red light can indicate that the router is undergoing a firmware update or configuration change. During this process, the router might temporarily show a red light, but it should eventually switch back to its normal state once the update is complete. If this is the case, you need to wait for a while before the light returns to normal.
on 02-08-2023 12:08
Update virgin did a few tests which made no difference so they sent me out a new hub 5 which seems to be working ok
on 02-08-2023 12:46
Hi cm56 👋 thanks for returning to the thread to keep it updated!
Pleased to hear a new hub has improved things for you. Please let us know if there is anything outstanding you need our support with so we can help.
Wishing you all the best! 🌞
on 04-09-2023 08:58
A permanent red light on your Hub 3.0 router, typically provided by Virgin Media in the UK, indicates a connectivity or service issue. This could be related to your internet connection, the status of your router, or other network-related problems. Here are steps you can take to troubleshoot and resolve the issue:
Check Virgin Media Service Status:
Restart Your Router:
Check Cabling:
Review Router LEDs:
Check Your Account Status:
Factory Reset (If Necessary):
Contact Virgin Media Support:
Remember that a permanent red light on your Hub 3.0 router typically indicates a significant issue with your internet connectivity. It's essential to work through the troubleshooting steps systematically, and if the problem persists, reach out to your ISP for further assistance. They can provide you with guidance tailored to your specific situation and may be able to resolve the issue remotely or through onsite support.
on 06-09-2023 09:14
Hi fedavid,
Welcome to the Community Forums!
Thanks very much for sharing this 😊
