Hi.
I have 2 tivo boxes in separate rooms, and therefore 1 white wall socket with a main cable in each room.
In the main room, the main cable has a splitter so it can connect to the tivo box and the hub 3.0 box.
Could I move the splitter and the hub 3.0 devices to the 2nd room? - is the signal coming from the white wall socket and cable the same for room 1 and room 2?
I want to relocate the Hub 3.0 so it's nearer more wireless devices as the signal is weak beyond 1 wall.
Also.. I did just buy an asus ac66u b1 router, but the signal is just as weak as the Hub 3.0. I did just update the firmware on the asus - could I expect the signal to have improved (not re tested it yet)?
