set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the Hub, it will take a few hours to get any kind of trend showing.
On here click the Link icon (2 link chain)
In the URL box paste the link you copied and then click OK
