Coner
Hub 3.0 flashing green base
Hello guys seem to be having issues with my Internet, the WiFi symbol stable green but the base light is flashing green. I have been with virgin for 2 month now, I haven’t ran into any issues apart from this today. My Network Log shows a “SYNC Timing Synchronisation Failure, a Loss MDD Time-out & Received Response to Broadcast Maintenance Request But no Unicast Maintenance opportunities Recieved ” if anybody could help that would be appreciated I have contacted vm and after over 1hour I have been disconnected. I have also checked all connection internally and nothing has changed since the installation date.
Tags (2)
  • 20.48K
  • 2.18K
  • 3.61K
Re: Hub 3.0 flashing green base
Have you checked for “known network faults”?
As well as trying the “check service,” Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level. These may not be listed on the Area Status web page (Areas are not “Geographic” they are billing areas) as that usually only covers faults affecting 1000’s of customers) so phone may give you more info, but even that wont cover problems affecting just a few customers.
Coner
Yeah I have tried that it also says there isn’t a problem
  • 20.48K
  • 2.18K
  • 3.61K
Yiu will have to call it in as a problem then to see what they say when they look at the connection
