Hi, our Hub .3.0 setup has suddenly stopped working
We have another router and a TP link hub (home and office) connected to Hub 3.0 ethernet ports, each has a couple of PCs logged in. Plus the Tivo box and the TV. We've had this setup for a couple of years fine.
Everything was fine until Friday afternoon when the ethernets stopped working. Looking at the Hub 3.0 logs a software update was pushed out. I don't understand all the other messages but now the ethernet connections are erratic. We thought it was the Netgear router as the other connections only worked when that was disconnected. We have swapped that out for another network switch, but we still can't get them all to stay working for more than an hour or so.
Have tried pinhole reset, switching on in different order etc.
The wifi is still working but not enough range for what we need.
Could the 5 year old Hub 3.0 be dying of old age?
Thank you in advance!
