Hello
Once your hub is in modem only mode make sure that you are using the correct power on sequence.
1) Power off both hub and your Linksys.
2) Power on the router and wait until the lights stabilize can take around 5 minutes.
3) Then power on the Linksys and let the light stabilize.
This should resolve your problem.
Regards Mike
