Kev_B
  • 8.07K
  • 288
  • 920
Community Manager (Retired)
Message 11 of 188
Re: Hub 3.0 and BT Whole Home WiFi
Hi @Weavels @Sharpey1970
I'm sorry to hear you've both had problems start on Friday. I've checked the hubs for both of you and it looks like you're still on the standard release firmware, so the problems you're experiencing aren't as a result of this rollout.
I'm double-checking with our firmware team to be 100% sure that the firmware version is different, I'll let you know once they confirm.
@jpeg1 are you having issues as well, or were you bumping for an update?
Kev
Weavels
  • 17
Message 12 of 188
Hi Kev
Thanks so much!
jpeg1
  • 4.78K
  • 264
  • 773
Superstar
Message 13 of 188
@Kev_B  I'm not having issues at the moment, but if there are likely to be further changes it would be good to have some advance notice.
bruno1926
  • 15
Message 14 of 188
I'm having the same problem with Bt wholehome mesh aswell as wifi dropping every 20 mins or so
Kev_B
  • 8.07K
  • 288
  • 920
Message 15 of 188
Hi again @Weavels @Sharpey1970
I've had confirmation from the hub team that the new firmware has a different version number, so it doesn't look like either of you is on the new firmware. That means the problems you're having are unlikely to be related. However, if you'd like to try the new firmware to see if that helps with the issues you're having then let me know. If not, could I ask you to post a new thread describing the issue you're having so that one of our team can look into it for you please?
@bruno1926 - it looks like you're on the standard firmware as well so the same applies. If you'd like to try the new firmware to see if that fixes the issue then I can certainly put you forward, otherwise I'll need you to create a new thread about the issues you're having so a member of our team can investigate.
Kev
Sharpey1970
Message 16 of 188
Hi Kev
Could we try updating the firmware in the first instance?
Tags (1)
bruno1926
  • 15
Message 17 of 188
Thanks for replying. The new firmware sounds like a plan  lets go for it.
dcw3003
  • 7
Message 18 of 188
I never had any issues with my BT Whole Home WiFi (Standard) discs, however have had intermittent (almost daily) issues with my BT Whole Home WiFi Premium discs. My issue is currently with BT 2nd line technical and they have advised I require a firmware update (to 9.1.1910.200); mine is currently 9.1.1811.401. Is there a way this can be pushed to my hub?
Mr_Mike
  • 19
Message 19 of 188
To be fair, if you go on the BT forums there are plenty of people there saying that the Premium discs are troublesome too, and not just with Virgin routers.
dcw3003
  • 7
Message 20 of 188
To be honest, I’m not entirely sure I believe the firmware update is going to work...but looks like I can’t get further help from BT without first getting the hub update.
