Hub 3.0 and BT Mini Home Wifi
Hi all,
I am looking for some help connecting the BT Mini Home WiFi to the VM Hub 3 with an ethernet backhaul.
Currently, the first disc is plugged in to the Hub (router mode, wifi disabled). The second and third discs connect to the first disc via wireless backhaul.
I would like to also plug the second disc to the Hub so that it is not relying on the wireless. However, when I do this, the disc goes from blue to red and no longer works.
I undersood that an ethernet backhaul is feasible with these discs, however, I cannot seem to get it to work. Does anyone have any experience in setting this up? Do I need to change the DCHP settings or provide a static IP?
Thanks in advance for your help
  • 20.96K
  • 1.14K
  • 2.7K
Re: Hub 3.0 and BT Mini Home Wifi
The Mini and Premium discs have many known issues with the Virgin Media hub whereas the standard discs work with no issues
