KTPOrange
  • 6
Message 1 of 5
Hub 3.0 always showing amber and cuts out.
my new virgin Hub 3.0 router is always amber. It works in the same room i am in but is slow upstairs. I’ve asked for another box so they are sending that but am concerned about why it would be that inefficient. I’ve followed all the steps to make sure the wifi router is free from interference and restarted but why would it still be amber and not be able to connect properly without additional little boxes?
  • 20.5K
  • 828
  • 2.2K
Message 2 of 5
Re: Hub 3.0 always showing amber and cuts out.
Maybe you have some missing Docsis channels?
you can log to the hub 192.168.100.1 and post as text downstream and upstream
  • 35.13K
  • 3.42K
  • 6.69K
Message 3 of 5
Amber light means nothing - its the common symptom of a failing./fading 1p LED in the Hub3. It has nothing to do with any connectivity issues.
By other little boxes - do you mean VM Pods and do you have them ?
KTPOrange
  • 6
Message 4 of 5
Hi thanks for your reply. I don’t have the boxes now but I’m waiting for them. I just didn’t have this issue with my last provider.
KTPOrange
  • 6
Message 5 of 5
Thank you I’ll try this.
