on 26-10-2023 14:45
A few days ago I noticed my hub 3.0 has a solid red light instead of the usual white one, and WiFi connection has been temperamental. I have followed the "Fix my broadband" steps in help as well as Resetting the router (using a pin in reset button for 60 seconds with no ethernet connected) and it is still red. Can you please advise if you can fix this Virgin Media?
on 26-10-2023 15:30
Hey @gm86,
Welcome to the Community Forums and thanks for the post.
I would like to go about arranging a technician for you to come look at your Hub and if required replace it, for me to do so I will need to confirm some information from you in a quick private message.
Joe
on 26-10-2023 17:05
on 03-11-2023 06:37
An engineer came out 2 days after my original post and replaced the hub with a new one, all resolved.
on 05-11-2023 13:10
Hi gm86,
Thanks for taking the time to update us in the Community. We're happy to hear the engineer was able to resolve things for you.
Please let us know if you have any further issues.
Many thanks,
