on 01-09-2023 07:56
lately I have been experiencing random and often frequent drop outs of my internet connection. I have cycled through the normal troubleshooting process, hard reset, checked cabled, there's nothing visually apparent. The cables outside the property are exposed, they are not properly protected.
The modem repeatedly throws this error SYNC Timing Synchronization failure - Loss of Sync, this has to be either hardware or fault on the link between my address the the Exchange.
I have had at least two technicians visits in the past 12 months to check resistance on the cables and found nothing wrong, I was also told that they can't do anything about the cabling because it was someone else's job.
I would really appreciate if VM rep picks this up and help me resolve this issue once and for all.
on 03-09-2023 09:15
Hi @tysyd2023
I am sorry to hear of the issue with the broadband. I've checked the system and there's an open fault you're affected by. F010917981 - fault number. The estimated fix date is today at 5pm. Hopefully that's fixed sooner for you.
I am going to send you a PM though because you've mentioned cables being exposed and am keen to get that sorted.
Best wishes.
on 03-09-2023 14:52
Hi @tysyd2023
Thanks for joining us on PM and allowing me to help you sort this 🙂
Please let us know how the visit goes.
Best wishes.
