Camokozzy
Hub 3.0 Red Light
Hello,
My hub is currently showing a red light, I had it switched off for 24hrs and turned it back on and it's still red, as per the posts on here it's an overheating issue. the hub is only a month old and sometimes the WIFI drops out as well.
lotharmat
  • 2.54K
  • 190
  • 462
Trouble shooter
Re: Hub 3.0 Red Light
Yup - that'll need to be replaced.
Is the Hub out in the open?
Camokozzy
yes it's in an open hall on a table with nothing beside or in front of it.
lotharmat
  • 2.54K
  • 190
  • 462
Trouble shooter
You could call it in as a fault on 150
It'll ask you to reboot the hub (as you already have done - don't)
You will then be cut off
Wait a couple of minutes
Call 150 again  - report a broadband fault - The system will recognise that you called before and transfer you to a person!
Don't let them fob you off with 'it's meant to do that' or 'if you upgrade your speed it'll be OK' - You wouldn't tolerate a broken brakes warning light on your car and neither should VM
Don't mention WiFi to them - just use the term broadband or you'll get a whole spiel about sorting your WiFi out.
(tell them the hub is pretty warm)
They should book an engineer who'll replace the hub! (if they have any)
Good luck! - Keep us posted!
Paulina_Z
  • 1.06K
  • 33
  • 67
Hi @Camokozzy,
Welcome to our Community Forums! Thank you for your post and I'm sorry to understand that you're experiencing some issues with your Hub!
It is definitely not ideal to have your Hub showing the red light. If you haven't already, you can take a look at what the different lights mean on our website here.
I was able to locate your account on our system, and in order to have this issue resolved, I will have to book a technician to look into this and potentially replace your Hub. I will need to send you a Private Message to confirm a few details.
Please keep an eye out for a purple envelope at the top right corner of your Forum page. I will be in touch soon. 🙂
Thanks!
Paulina_Z
Paulina_Z
  • 1.06K
  • 33
  • 67
Hi @Camokozzy,
Thank you for getting back to me via Private Message to confirm your details.
I was able to schedule your appointment for the first available date. You can track and manage your appointment on your online account.
Please keep us updated on your technician appointment and let us know if there's anything else we can do to help further.
Paulina_Z
