DougiePR
  • 5
Message 1 of 9
Hub 3.0 Red Light
Hi all,
For the last month or so the power light on my hub 3.0 has been showing as red, and not the white it once was.
The hub is in router mode, is not in an enclosed space and it's been in the same place since we have Virgin Broadband installed almost a decade ago.
The WiFi drops on it at least once a day.
It's worth noting that the Hub has been switched off and on again more times that I can count, along with a number of 'factory resets' none of which have made any difference to the issue.
I'm posting this the hope that a member of the Virgin team see this and offer help as I've been 'told off' for contacting a member of the team via direct message.
Dougie
Zak_M
  • 4.44K
  • 259
  • 421
Message 2 of 9
Re: Hub 3.0 Red Light
Thank you for coming back to us @DougiePR
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with your services.
Are you able to let me know, is your hub in modem mode or router mode?
Kind regards,
Zak_M
DougiePR
  • 5
Message 3 of 9
Morning Zak,
As mentioned in my initial post the hub is in router mode.
Dougie
Zak_M
  • 4.44K
  • 259
  • 421
Message 4 of 9
Sorry about that @DougiePR
I missed that, the red light could mean that the hub is overheating we are best to get this replaced, at the moment the hub 3 stock is protected due to a stocking issue, therefor we will need to get an engineer out.
I will pop you over a PM so that I can confirm your address.
Kind regards,
Zak_M
DougiePR
  • 5
Message 5 of 9
Thanks Zak,
I appreciate your help 👍 and await your DM.
Zak_M
  • 4.44K
  • 259
  • 421
Message 6 of 9
It should be with you,
Please check the purple envelope on the top right of the screen.
Kind regards,
Zak_M
DougiePR
  • 5
Message 7 of 9
Excellent, got it and replied 🙂
Zak_M
  • 4.44K
  • 259
  • 421
Message 8 of 9
Thank for confirming that information via PM.
I have booked the engineer to attend.  you can check the time and date via your online account, once there if you want to change the time and date you are able to do so.
Kind regards,
Zak_M
DougiePR
  • 5
Message 9 of 9
Thanks for sorting that for me I appreciate it. Fingers crossed they'll be able to sort it for me
