swcomp
Message 1 of 7
Hub 3.0 Red Light
I am new customer and since install my Hub 3.0 had an orange power light which has now become red for the last few days. The power light is red even from a cold start.
I have done several factory resets of the hub and multiple reboots with no change. After a reset the power light sometimes flickers from white to red for a minute then goes to red.
I have been trying to get support through the messaging/chat for two days now with some "hello" replies but no further action or help.
Broadband and wifi is ok but based on other threads I have read I would like to request a replacement hub 3.0 in case the cause is an electrical fault.
Tags (1)
Emma_C
  • 8.28K
  • 512
  • 559
Message 2 of 7
Re: Hub 3.0 Red Light
Hi Swcomp,
Very sorry you're having some issues with your hub light being red, this isn't good.
We agree with you and therefore a new hub is on it's way, this will arrive over the next few days and will just need activating.
Any issues with this please do let us know as soon as possible.
Emma_C - Forum Team
swcomp
Message 3 of 7
Hi Emma_C,
Thank you for your prompt action, your help is much appreciated.
Best regards,
swcomp
Chris_W1
  • 4.06K
  • 185
  • 255
Message 4 of 7
Hi swcomp, I am glad to see that this is on the way to getting resolved, please let us know how it goes and if you need any further assistance? Chris
swcomp
Message 5 of 7
Hi Chris,
Thanks for checking how I got on.
I received the new hub ok and it has been working fine the last few days. I will be returning the old hub very soon.
Best regards,
swcomp
luissequeira
  • 8
Message 6 of 7
Hello, could you please let me know how to fix this, I am having the same issue.
Kath_F
  • 28.12K
  • 1.08K
  • 2.17K
Message 7 of 7
Hi luissequeira,
Thanks for your post and apologies to see you are having the same issue. I've just replied to your thread here: Hub 3.0 Permanent Red Light
Please make sure you are only posting once about your issue. If you need to update the thread then just reply to your original thread rather than creating a new one. We understand it's frustrating when something's not right however posting more than once about the same fault makes the boards look busier than what they actually are. It also means we could take longer to reply due to needing to sift through duplicate posts.
Have a look at my reply on the other thread and stick with that one so we keep all the information in one place.
Kath_F
