Hub 3.0 Power Range
Hi All,
I'm trying to confirm if the below power on my upstream channels is as low as previous posts lead me to believe.
1394000494.075512064 qam4
2603001523.65512064 qam1
3537000003.725512064 qam2
4462000103.775512064 qam3
3ATDMA0000
4ATDMA0000
I also seem to have quite a few Pre and Post RS errors, and the below in the logs.
15/02/2020 13:29:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2020 13:29:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2020 13:29:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/02/2020 13:29:22critical
Does anyone have any hints on how to fix this?  My internet connection is very intermittent to all devices and is off more often than on at the moment.
Thanks!
  • 3.52K
  • 567
  • 1.38K
Re: Hub 3.0 Power Range
Upstream power levels look fine - the generally accepted range is between 31 and 50 dBmV, although ideally mid way between those.  There's a long standing bug that causes the hub to misplace the decimal point, so your figures are actually 36.5 dBmV to 40.75, and that should not be causing the problems you are experiencing.
The bug is good to know.
Anyone have any ideas on the Time Sync issue showing in the messages?
  • 3.25K
  • 135
  • 189
Thank you for your post I_am_jon.
We can see there is a known area fault which may be affecting your services, I will include some information on this below:
Reference: F007798147
Estimated fix time: 18 FEB 2020 09:00
You may be able to see updates for this on our service status page, if this isn't affecting a wide area of customers it will not show here but you can request an update from any agent by quoting the reference listed.
Thank you, Emily.
