Hub 3.0 Keeps Rebooting
  • Hey everyone,
I've had serious issues with my Hub 3.0 router today. It has been constantly rebooting itself every few minutes for more than 16 hours now.
I've tried rebooting, checking connections and running VM online diagnostic tools. Nothing has worked.
When the router restarts our Internet does work for like 5 minutes but then the whole thing reboots and the whole circus begins again.
I've also tried Virgin Media support via phone and live chat but have been left without answers or on hold for hours without any advice or help. So now I'm here!
Here are a few lines from our Router Status page, hopefully they help.
Upstream Tab:
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
14620000046.3512064 qam3
23940000046.3512032 qam4
35370000046.3512064 qam2
46030005846.3512064 qam1
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Downstream Tab:
1331000000-7.538256 qam25
2267000000-5.940256 qam17
3275000000-6.440256 qam18
4283000000-6.738256 qam19
5291000000-738256 qam20
6299000000-7.738256 qam21
7307000000-8.538256 qam22
8315000000-8.238256 qam23
9323000000-7.538256 qam24
10339000000-7.938256 qam26
11347000000-8.238256 qam27
12355000000-8.238256 qam28
13363000000-8.238256 qam29
14371000000-8.538256 qam30
15379000000-9.237256 qam31
16387000000-9.738256 qam32
17395000000-1037256 qam33
18403000000-10.537256 qam34
19411000000-11.736256 qam35
20419000000-13.335256 qam36
21427000000-15.533256 qam37
22435000000-18.830256 qam38
23443000000-22.427256 qam39
24451000000-22.327256 qam40
1Locked38.6100
2Locked40.3120
3Locked40.340
4Locked38.9110
5Locked38.960
6Locked38.650
7Locked38.620
8Locked38.900
9Locked38.950
10Locked38.6120
11Locked38.600
12Locked38.690
13Locked38.660
14Locked38.6150
15Locked37.3120
16Locked38.670
17Locked37.3140
18Locked37.6180
19Locked36.3190
20Locked35500
21Locked33.821850
22Locked30.812635080
23Locked27.91733409618157
24Locked27.417434390434019
Network Logs:
TimePriorityDescription
14/11/2020 00:29:13ErrorService Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:28:7ErrorService Change rejected - Required parameter not present;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:26:57ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:26:34ErrorService Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:22:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:21:13ErrorService Add rejected - Required parameter not present;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:20:27ErrorService Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:20:22ErrorService Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:17:57ErrorDCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:15:45ErrorService Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:13:28ErrorService Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:05:49ErrorDCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:04:32ErrorService Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:03:39ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:01:39ErrorService Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:00:54ErrorDCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:00:51ErrorService Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:00:47ErrorService Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 00:00:32ErrorDCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 23:57:51ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Hopefully someone can help with this issue, working from home depends on this!
Cheers
Tags (3)
  • 24.48K
  • 1.4K
  • 3.11K
Re: Hub 3.0 Keeps Rebooting
Your downstream levels are too low.
Is there an attenuator fitted to the back of the hub?
Hey, no attenuator attached.
  • 24.48K
  • 1.4K
  • 3.11K
Unless there’s an area issue you’ll need an engineer visit.
