  • 8
Message 1 of 18
Hub 3.0 Doesn't work
Can someone give me a real support ar advice or something on what else I need to do, to get into this hub? The classic way of doing it wich is to reset the hub, turn it off/on it doesn't work at all!!
Please help!
  • 25.16K
  • 1.44K
  • 3.21K
Message 2 of 18
Re: Hub 3.0 Doesn't work
What are you trying to do exactly?
  • 8
Message 3 of 18
I just want to get access into my hub 3.0 and I can't by using that 8 figure password at the bottom of that hub.
  • 25.16K
  • 1.44K
  • 3.21K
Message 4 of 18
Are you entering the settings password and not the Wi-Fi password?
  • 8
Message 5 of 18
100% i did the right password.
  • 25.16K
  • 1.44K
  • 3.21K
Message 6 of 18
If it’s not working then do a 60 second pinhole reset on the hub
  • 8
Message 7 of 18
I did it as well. Not working! Someone from @virgin maybe can do something about it?!
  • 25.16K
  • 1.44K
  • 3.21K
Message 8 of 18
Possibly. Response times are 5-7 days
  • 1.91K
  • 74
  • 138
Message 9 of 18
Hi stmyield,
Welcome to the Community and thanks for posting.
We apologise for the delay in response and for the issue you are experiencing with the Hub.
Have you been able to access the Hubs information since your last post to us? If not, please let us know and we will be happy to assist further.
Thank you
Nat
  • 8
Message 10 of 18
Hi there!
I still got the same issue where I can't get into my Hub settings using the password on the back of it. By the way, I noticed that the issue with connection persisted only when I switch on my VPN on Norton Antivirus. Is there any fix for that because I really want to use VPN? According to the other forums I've checked, I have to change my NAT Type to OPEN, but I can only do this by accessing my Hub setting.
