Message 1 of 5
Hub 3.0 Constantly disconnecting devices from wifi
Hi community,
I've seen numerous posts about this but really not too clear on the fix. All our devices are consistently disconnected from the wifi. There seems no clear pattern to this but it has been particularly bad during the day time - a great frustration given both of us are working from home during the lock down. It's getting to the point where we are considering leaving after many years with Virgin. Posting the hub details I've seen requested elsewhere.
When plugged in via a cable the internet seems stable and consistent so it appears predominantly WiFi orientated. We have done a pin hole reset recently too to no avail.
Please help!!
1411000000038256 qam31
2195000000037256 qam8
3203000000-0.537256 qam9
4211000000-0.737256 qam10
5219000000-137256 qam11
6227000000-2.237256 qam12
7235000000-337256 qam13
8243000000-2.737256 qam14
9251000000-1.237256 qam15
10259000000-138256 qam16
11267000000-0.738256 qam17
12275000000-0.538256 qam18
13283000000-0.438256 qam19
14291000000-0.238256 qam20
15299000000038256 qam21
163070000000.238256 qam22
173150000000.538256 qam23
18323000000138256 qam24
19363000000-0.738256 qam25
20371000000-0.538256 qam26
21379000000038256 qam27
223870000000.238256 qam28
23395000000038256 qam29
244030000000.238256 qam30
1Locked38.960
2Locked37.6220
3Locked37.3180
4Locked37.6230
5Locked37.6210
6Locked37.6370
7Locked37.6360
8Locked37.3200
9Locked37.3210
10Locked38.6130
11Locked38.680
12Locked38.680
13Locked38.6100
14Locked38.6120
15Locked38.6490
16Locked38.9310
17Locked38.9250
18Locked38.960
19Locked38.9240
20Locked38.9110
21Locked38.6110
22Locked38.6140
23Locked38.9140
24Locked38.9100
1602999764.875512064 qam1
2393999794.625512064 qam4
3461999984.725512064 qam3
4536999794.725512064 qam2
Message 2 of 5
Re: Hub 3.0 Constantly disconnecting devices from wifi
Primary Upstream Service Flow
SFID863
Max Traffic Rate22000061
Max Traffic Burst42600
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
17/04/2020 09:53:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2020 09:12:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 23:49:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 14:56:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 09:47:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2020 12:07:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2020 14:22:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2020 02:23:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 01:50:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 01:50:12ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2020 19:01:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2020 13:45:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/04/2020 22:35:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2020 11:55:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 18:43:47noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 18:43:47ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 13:00:39ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 07:54:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 07:17:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20.96K
  • 1.13K
  • 2.7K
Message 3 of 5
You need to look into getting a mesh system or a better standalone router to improve the WiFi then
Message 4 of 5
Thanks for the comment. But why should this have to be the case when I'm paying Virgin to provide a decent enough service or level of tech?
  • 94
  • 27
  • 31
Message 5 of 5
Most internet providers can only guarantee speeds TO the property, WiFi performance from the hub onwards can vary greatly from home to home. Any extra outlay to improve WiFi should be seen as an investment, as that equipment will be yours to keep and the only change from that point forward would essentially be any given provider.
Dean M.
