on 19-05-2022 16:37
Recently upgraded to M500 connection, get full speed on wifi stood next to the hub, but when I connect ethernet, it tells me it's got a 100/100 (mbps) link speed. While this is alright, it's not the full 500mpbs I was hoping for to my PC.
I've had a quick look at the admin pages for the hub, but haven't found a way to change the link speed. Is it possible? My network port is capable of 2.5Gbps and the cable is a Cat8 ethernet cable.
on 19-05-2022 16:40
on 19-05-2022 16:51
Hi jbrennand,
I went into control panel and set my speed from auto to 2.5Gbps Full Duplex so I think that's sorted (could very easily be wrong). Powerline connection to another device is showing the same link speed, so I've got a feeling it must be a setting somewhere...
on 19-05-2022 18:02
on 19-05-2022 19:48
Sadly, I think you may be right...
The powerline adapters state 1300 mbps but sit below 100 when I use them. Plugging in directly gives me in excess of 500mbps
It's a shame it's not feasible to have a standard cable going to my router and the WiFi signal doesn't seem to reach
on 20-05-2022 14:25
on 20-05-2022 14:35
So the issue seems to be that the powerline network is rated at well over gigabit speeds, but the ports on the adapter itself are each limited to 100mbps, which to me seems like terrible design.
I'll look into extending my WiFi through either an access point closer to the devices upstairs or through mesh networking, I'll have a look and see what would work best for the house.
Thanks for your help.
