Does look like a connection issue. Can you reset it as per below and see that the RS error counts all reset to 0 (press the reset counter buttons if they dont). Then see if they start increasing into the 1000's - they shouldn't (although a few hundred is normal for an SH2
Also, post a link to the "share live graph" so we can see what the connection is like now.
Put the Hub3 on and see what its like - you can keep the SH2 and ask them to reactivate it onto your account if it's worse.
________________________________________
First, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box. Then switch it on again and leave 5 minutes
Then Do a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
