chammonduk
Hub 2 needs constant resetting
I am having problems with my Hub 2 router. I have to keep rebooting it to get a connection. It's the same with all same with all devices, even my smart TV which is hardwired. I have tried a factory reset on the router but the problem still remains. It is quite annoying because I sometimes have to work from home and my granddaughter who is living with us has to do online schooling at the moment.
Sabtain7
  • 95
  • 5
  • 10
Up to speed
Re: Hub 2 needs constant resetting
Hi, you will be eligible for a hub three the hub 2 is quite outdated I would recommend phoning Virgin Media Customer Support explaining that your hub randomly switches on and off (you need to say this so they know it’s a hub fault otherwise They will go through some other steps which in my opinion are irrelevant for you) and they will send out A hub three for you with self install this should massively improve your home broadband system and fix your issues as from what you are saying i believe the hub is on its way out
If I Have Tried To Help You Hope It Helps:
I am fairly knowledgeable about technology in general and will try to help you to the best of my ability.
Sky World Customer (TV), Virgin Media Fibre Optic Gig1; Virgin Media Phone Package
Want To Contact Virgin Media's UK Call Centre?
Here's How:
STEP 1: Dial 150 (Virgin Landline) or 0345 454 1111 (Non Virgin Phone)
STEP 2: Option 1 for TV, Broadband or Home Phone
STEP 3: If The Number You Are Calling From Belongs To Your Virgin Media Account Select Option 1 If Not 2 (then enter the Virgin Media Home Number or press # then tap in Virgin Media Account Number
STEP 4: Select Option 4 - To Make Changes To Your Package Or Tell Us You Are Moving
STEP 5: Select Option 4 - If You Are Thinking Of Leaving Us
STEP 6: Select Option 2 - If You Are Thinking Of Leaving Us For Any Other Reason
UK Call Centre Times:
Mon - Fri 8am - 9pm
Sat - Sun - 9am - 6pm
  • 20.43K
  • 2.18K
  • 3.61K
It may be the SH2 - which VM will replace for free - but they usually want to check to see if there is a network connection issue first. To do that can you follow this.
____________________________________________________
In your browser’s URL box type in http://192.168.0.1  (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before click on the “router status” icon/text t the top right corner of the first page up and then copy/paste as “Formatted Text” (not images) 3 FULL sets of data onto here – the Downstream, the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again.
Also, in the meantime... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
chammonduk
Thanks for the advice. Engineer called and gave me a Hub 3. Everything working properly now
Thanks everybody👍
