grops86
Message 1 of 16
How to order Wi-Fi pods
Hi, I was trying for 1hour scan my house for Wi-Fi coverage, but I can’t do it as my Wi-Fi keeps cutting off. This happens on 2 sides across my house so I guess I need 2 pods to keep it running smooth. I am on volt package so as far I know I can have them with no extra cost. The only problem is during the scan I can’t see any option to order them. How to solve this?
Tags (1)
  • 35.13K
  • 3.42K
  • 6.69K
Message 2 of 16
Re: How to order Wi-Fi pods
See my reply to the same question below
https://community.virginmedia.com/t5/Networking-and-WiFi/Order-a-wifi-pod/td-p/5260466
Ilyas_Y
  • 2.48K
  • 86
  • 218
Message 3 of 16
Hi there @grops86, thanks for reaching out to us and a warm welcome to the Virgin Media forums.
I'm sorry to hear about the issues with the Connect App and the Wi-Fi when you're trying to scan the house.
I will be able to assist you on this and get the Wi-Fi pods sent out.
I will send a private message - watch out for the purple envelope inviting you in.
Kind regards,
Ilyas.
Ilyas - Forum Team
Pinkle89
Message 4 of 16
Hi I've got the same issue with WiFi completely dropping out so I can't go through on the app, could you help me too?
Megan_L
  • 3.9K
  • 219
  • 391
Message 5 of 16
Hi Pinkle89,
Thanks for using the forums to get this issue with your WIFI looked into, I am sorry if this has been causing issues whilst trying to order WIFI pods. I would be more than happy to look into this for you.
I have checked on my side for any issues that could be causing your WIFI to drop out and I can see that your Hub hasn't been rebooted in nearly 5 weeks, if you could please try rebooting your Hub and allow it to settle after the reset it may rectify your WIFI issues.
We usually recommend rebooting the Hub every 2 weeks so that the data and stats can refresh, otherwise it could cause congestion along with intermittent/slow connection like you're experiencing now. I would also highlight this really helpful page about WIFI issues which may help too 👉 WIFI Issues.
Please let us know how you get on with the Connect App after doing this.
Megan_L
Pinkle89
Message 6 of 16
Hi I've rebooted the hub and then got a connection of 6Mbps in the bedroom, I can't get through to anything on the website even though it's come up with the poor connection, anything you can do to help?
John_GS
  • 15.74K
  • 798
  • 1.46K
Message 7 of 16
Hi @Pinkle89
Thanks for coming back to the thread.
Have you used the Connect App to do the test? If so, have you done a full scan of the property?
Kind regards,
John_GS
Pinkle89
Message 8 of 16
Hi yes I did use the connect app, pretty much every room is ok but the bedroom is a black hole, if there's a connection in there it's very low rate, it showed up on the app as 6Mbps.
Trying to do the test on the app I had to attempt about 5 times before getting anything but oops something went wrong, try again in 10 minutes
Lee_R
  • 6.89K
  • 327
  • 738
Message 9 of 16
Hi @Pinkle89 thanks for getting back to us.
Sorry to hear that you've been unable to order your pod via connect app. And sorry that you require a pod.  I would like to help you with this.  I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
Ilyas_Y
  • 2.48K
  • 86
  • 218
Message 10 of 16
Thanks for speaking with us today @grops86 on the forums. 🙂
I'm glad we have been able to order the Wi-Fi pod.
As advised - you will get updates on the delivery date sent to you.
Let us know how it goes with the Wi-Fi pod when it arrives.
Kind regards,
Ilyas.
Ilyas - Forum Team
