How to open a port on Virgin Media Hub 6 (port forwarding)
larkapal
How do I open a port on my Virgin Media Hub 6? I have tried the TCP/UDP settings both inbound and outbound in the IP and Port Filtering section in the Hub settings, yet the port I need open remains closed upon a port scan. I need to be 'connectable'. Please help. I need instructions.
Thank you in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
Are you based in Ireland?
I believe they use IPV6 so it would be interesting to see what IP address you are trying to use to check if the port is open!
It appears you shouldn't have access to the port forwarding options at all when on IPV6.
https://www.reddit.com/r/VirginMedia/comments/lk4e9t/port_forwarding_on_ipv6/
12 REPLIES 12
from Ireland?
you need to talk to Ireland VM for IPv4
What does that mean?
We just got this new hub from Virgin. I'd like to know how to open ports on it. Surely that instruction would be the same with the same equipment anywhere.
Well if it was simple to do you would of found what your looking for by now.
Hi @larkapal
VM don't have a hub 6. The latest version is the hub 5 which supports WiFi6
Some ports are blocked - see the Virgin Media's Blocked Internet Ports section on the following page
https://www.virginmedia.com/help/broadband/enhance-your-wifi-security
Dave
The do's and don'ts.
Cardiffman282
Superfast
I don't know if this thread helps.
If it were simple to do, I wouldn't be here in the first place. Now, are you going to actually help, or just talk trash to me?
Are
You
From
Ireland?
That answers my question exactly. No port forwarding on IPv6 at all! Thank you!
