How to get a hub upgrade
Hello i have 6 years old hub and it have some issues. How can i upgrade or replace for an other?
  • 4.37K
  • 743
  • 1.78K
Re: How to get a hub upgrade
No point trying to phone at the moment, so try the online upgrade form:
https://www.virginmedia.com/shop/hub-swap?buspart=uk_app_connect2_hubswap
Even then, don't expect too quick a response, nor expect a guarantee of trouble free setup.  But people round here will help you get the best out of a Hub 3 if it does misbehave.  Under ideal circumstances the Hub 3 achieves heights of adequacy, so you might find it meets all your needs.  If not, ask the forum.
