@Usaydlatif96 wrote:
Tried this, still does not let me disable smart wifi
But it's let you select 'manual' channel selection....
If you reselect 'Auto' for each of the bands does it let you click disable then?
Bug? Reboot the hub?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
