How to change WiFi channel on hub 3 as my printer won't connect to current channel it is on.
How do I change WiFi channel on my hub 3 as current channel conflicting with another so my printer won't connect to it. Very frustrating
  • 15.27K
  • 1.17K
  • 1.92K
Re: How to change WiFi channel on hub 3 as my printer won't connect to current channel it is on.
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3, Hub 4 is similar.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
  • 4.34K
  • 358
  • 618
Community elder
Check 'Disable Channel Optimization' and choose the least congested channel for each band by checking 'Auto', then using the drop down.
