siborg97
How many devices can connect?
Does anybody how many devices can be connected to the router?
At the moment I have 9 wireless devices connected to my router.
If I connect more does the service deteriorate?
Tags (2)
lotharmat
  • 937
  • 70
  • 141
Well-informed
Re: How many devices can connect?
Potentially.. A lot will depend on the exact set up you have - ie walls, proximity to router!
The VM hubs are pretty bad to be honest so if you get your own kit, you will be able to connect a lot more devices.
VM have a bad habit of saying you need to upgrade your speed to be able to connect more devices but this is not true.
I've had 10 devices connected to the Hub 3 with no issues but I've heard people say that VM customer services have said "5 - that's too many WiFi devices"
If you aren't having any issues with 9 - fine!
