Conbrue
  • 16
Message 1 of 7
How many WiFi devices is too many
Hello,
My WiFi seems to be struggling, most of the time showing full signal on iPad/phone etc but things are taking too long. Ran the WiFi test in every room and it came back as excellent in every corner of every room.
now, I do have a lot of devices for my smart home, 40 at least connected and that isn’t including the laptops, TVs etc, is there a limit?
only been with Virgin since this week, moved from Sky and I must say I am worried I have made the wrong choice, I work from home and I was even struggling with Teams calls which I never did on the sky BB. I have 600mb BB with Virgin.
ta
jb66
  • 12.14K
  • 899
  • 1.75K
Message 2 of 7
Re: How many WiFi devices is too many
The hub is a basic budget router, I would say it won't be able to handle 40 wireless devices reliably. Your really bordering a business grade router at that amount
gary_dexter
  • 30.36K
  • 1.88K
  • 4.04K
Message 3 of 7
You need a decent home/consumer router or mesh system.
Look at something from TP-Link or ASUS
Conbrue
  • 16
Message 4 of 7
Would I use a new router in addition to the VM one? Separate networks for the home automation makes sense but when I called VM about moving to them I did mention I had lots of devices.
Anonymous
Not applicable
Message 5 of 7
you could out the hub into modem mode and connect your new router. the hub then just acts as a modem
  • 2.87K
  • 215
  • 610
Trouble shooter
Message 6 of 7
@Conbrue wrote:
<snip>   only been with Virgin since this week, moved from Sky and I must say I am worried I have made the wrong choice, I work from home and I was even struggling with Teams calls which I never did on the sky BB. I have 600mb BB with Virgin.
ta
I think the Teams issue would relate to Sky having a much lower latency than VM.  As for having 40 devices, agree with the previous posters, the Hub will struggle.  Best to invest in a better wifi solution, with either something like Unifi Access Points, or a decent Mesh system.
Paulina_Z
  • 447
  • 15
  • 26
Message 7 of 7
Hi @Conbrue,
Welcome back to our Community Forum! Thank you for your post, we really appreciate it!
I'm sorry to hear that you're experiencing some connection issues with the amount of devices you have.
Are you experiencing this issue on just WiFi connected devices, or on wired devices also? Do you have any active Ethernet connections?
Please keep us updated on your connection issue and how it's going at the moment.
Thanks!
Paulina_Z
