The max traffic rate looks fine, and since you're using CAT6 it feels unlikely that it's a cable issue.. are you certain the network card is a 1gb NIC?
Either check "connected devices" on the hub, and see what it reports as the link speed, or check the link speed on the device you're connected with..
