adamace
How do i split wifi on superhub 3
Hi all was hoping I could get some help, I'm using the super hub 3 and when I connect to its WiFi I'm only getting the 2,4ghz show up no 5g at all, from what I've been reading up on, I need to split the 2,4 and 5g into two different channels, could someone tell me how this is done plz , thanks in advance
lotharmat
  • 2.54K
  • 188
  • 462
Trouble shooter
Re: How do i split wifi on superhub 3
You can split the WiFi bands by accessing your hub settings - to do this, you'll need to be connected to your hub and type in 192.168.0.1 into your web browser. You;ll then need to enter your hub's setting password (this can be found on the bottom of the hub).
Once you've access the dashboard, you'll need to go to advanced settings and then wireless - security. From there, you just need to change the SSIDs of both the 2.4ghz and the 5ghz signal to different names, you can just add on 2G and 5G to the end of the current network name.
Hit Save and then it should work!
Bear in mind that you'll have to reconnect all of your devices to the new SSIDs
adamace
Thank you so much that's most appreciated
lotharmat
  • 2.54K
  • 188
  • 462
Trouble shooter
No problem at all! - Glad to be able to help!
Any issues - Pop back on here and we'll do our best to help!
