Hat17
How do I order WiFi pods
how do I order WiFi pods please
  • 15.82K
  • 2.1K
  • 4.97K
Re: How do I order WiFi pods
Hi @Hat17
You need to use the Connect app to perform the Home Scan in the area where the signal is low(est)
Info below from https://www.virginmedia.com/help/booster-and-wi-fi-pods
Can I order a WiFi Pod on the Virgin Media Connect app?
Yes, but only if you’re not getting download speeds of at least 20Mbps in every room.
Our home scan feature will guide you from room to room to carry out WiFi speed tests. If it finds a potential signal-less spot, it’ll test our broadband speed to the WiFi Hub to make sure there isn’t a problem with your network. If everything’s okay with the Hub, the app will take you through to order a WiFi Pod to help boost your WiFi connection.
You can also call 150 from a VM landline or mobile, or 0345 454 1111 from any other phone to order a pod (they will only send out one at a time, and there must be an interval of at least one week before a second order will be accepted)
Call around 8am if possible when lines first open and are least busy.
They are free if you are on the Gig1 package, or Ultimate Oomph, or on a Volt bundle, however if you are on any other package then they are £8  a month.
Dave
Love, love and love, forever - Pele
metalguru
  • 33
Don't work and neither does the Connect app. Total garbage
Carley_S
  • 3.06K
  • 162
  • 263
Hi @metalguru
Welcome back to the community.
It's very disappointing to hear you feel this way. I can see that you have your own thread open on this issue and that my colleague has responded so we can support you further.  Please respond to her on your thread and we can assist you in hopes to get this resolved for you.
Carley - Forum Team
