on 22-01-2023 18:49
How do I get my 2.4GHZ devices to connect to my hub 5
on 22-01-2023 19:12
Have you tried
briefly disabling the 5Ghz WiFi on the Hub 5
or splitting the SSID's of 2.4 & 5 Ghz
or even Disabling WPA3
on 22-01-2023 19:16
Wife won't let.me in to the hub but if it work's will try anything
on 22-01-2023 19:57
At risk of enraging the Memsaab ...
The link to login is : http://192.168.0.1
The password for the Hub 5 is on a sticker, might be on the bottom side.
